how to save data in spreadsheet???
here is the audio analysis with sound card vi, i would like to ask how to save the data in the spectrogram to spreadsheet~
i want to save the data for frequency and the time~
thanks~
Message 1 of 15
(4,921 Views)
Hi Mashimaro,
in the waveform functions palette you will find the function "Export waveforms to spreadsheet file". Did you try that one?
Message 2 of 15
(4,917 Views)
can u help me solve the vi?
thanks a lot~
Message 3 of 15
(4,908 Views)
Hi Mashimaro,
just play around with those file saving functions:
Message 4 of 15
(4,878 Views)
i m trying but i dont know why the peak detector have problem..
it's like this what you mean?
Message 5 of 15
(4,858 Views)
hi again~
do you know how to save spectogram in spreadsheet?
i mean the frequency vs time~
Message 6 of 15
(4,813 Views)
Hi Mashimaro,
peak detector:
What kind of problems do you see? I don't know the data you supply to that function...
saving spectorgramm:
You're using a chart to display the spectogramm. Either write each line of data to a spreadsheet and prepend a time value as first element OR read the history of the chart (as 2D array) and prepend a time column before using WriteToSpreadsheetFile...
Message 7 of 15
(4,809 Views)
sorry, i don't know much about labview...
what i want to do is, as u seen in the figure, that is the online spectrogram monitoring sound card..
i am using microphone to get the waveform, and at the spectrogram there, i want to save the data in frequency and time..
do you know how??
thanks for your help..
i am using labview 2012..
Message 8 of 15
(4,806 Views)
Hi Mashimaro,
the attached picture doesn't resemble the VI shown before...
Your spectogram is provided as 2D array. Save that using a WriteToSpreadsheetFile function...
I don't know the two functions you use to create the spectogram, so I can't tell much about the data displayed in "spectogram".
Message 9 of 15
(4,798 Views)
ya, it is different with previous vi,
i want the value for the frequency and time at the spectrogram,
do it possible to save the data to excel,
i want to collect the data, i mean the frequency of voice..
Message 10 of 15
(4,790 Views)
