how to replace extra local variables
DFGray,
Can you provide, or point to, a demo showing how to use New Data Value Reference to communicate between two loops?
Thanks.
Richard
Message 21 of 29
(2,681 Views)
From the LabVIEW 2009 help:
You also can use a data value reference to store data without creating extra data copies. Data value references are slightly more efficient than queues but have no timeout options. Instead of transferring data to a queue, you can create a reference to data and pass around the reference. To operate on the data, use the In Place Element structure. The Data Value Reference Read / Write Element border node accepts a data value reference as an input, allows you to operate on the data within the In Place Element structure, and replaces that data in the original memory space.
Attached a small example.
hope this helps,
Norbert
[Edit]: Correction done in example....
Message Edited by Norbert B on 08-21-2009 02:55 AM
Norbert
Expert: Geometry
Message 22 of 29
(2,663 Views)
Information about the Data Value Reference is also already on the forums, please see this link
Norbert
Norbert
Expert: Geometry
Message 23 of 29
(2,646 Views)
Very nice, thanks Norbert. Smiley Happy
Richard
Message 24 of 29
(2,634 Views)
hello Mr.Patha,
i also had the same situation, please guide me, thank you
zainudin
here is my vi
Message 25 of 29
(2,481 Views)
i'm sorry, subvi for the main vi
Message 26 of 29
(2,477 Views)
here another link to main vi
Message 27 of 29
(2,459 Views)
Message 28 of 29
(2,457 Views)
Zainudin,
The way to get around using local or global variables changes depending on how you're using them. If you're using them to pass data, then the posts by DFGray should explain the options.
If you're using them for control of your application, then the best approach will probably be a state machine. You can also use a cluster with all of your settings and pass it through a shift register to the different loops.
Jared S.
Applications Engineering
Message 29 of 29
(2,429 Views)
