how to replace extra local variables
It seems I got way too many local variables in my VI.  Is there any way I can replace them with a data server?
Message 1 of 29
(5,430 Views)
What do you mean by this? Smiley Indifferent I dont know such anything in LV. All I know is VI Server.
You can use SRs to reduce the no. of locals (or even eliminate it). Smiley Wink
Or, post your code & we may try to help you out in a better way. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 29
(5,422 Views)
Thansk for the response.  What are SR's?
Message 3 of 29
(5,414 Views)
It's a shift register.
Norbert
Norbert
Expert: Geometry
Message 4 of 29
(5,410 Views)
I need to pass value across different while loops.  Can shift registers accomplish that?
Message 5 of 29
(5,400 Views)
hellolv wrote:
What are SR's?
Not to undermine your knowledge or make you fun of, just curious...
Do you not really know what SR means colloquially after some years of LV programming... ?!
Message 6 of 29
(5,415 Views)
This can be achieved by Queues.
What is your overall architecture?
Message 7 of 29
(5,393 Views)
Sometimes, when writing applications very fast (such as in the lab hunkered over a machine in 95% humidity) I might pepper the code with local variables like you have done, but 95% of them will get replaced with Shift Registers, Notifiers, or Queues when I get 15 minutes to clean up the code.
Read up on Producer / Consumer archetecture.
Message Edited by Broken Arrow on 08-18-2009 07:21 AM
Richard
Message 8 of 29
(5,385 Views)
If the while loop is a little oversized, any other suggestions on how I can pass data?
Message 9 of 29
(5,352 Views)
Got about two dozens of while loops running in parallel and bunch of data needs to be flowing back and forth between them.
Message 10 of 29
(5,350 Views)
