how to read sensor digital input and output using labview
hi all,
 I am currently using labview and EPOS 2 50/5 to control my humanoid robot.. I am required to use a sensor (GP1S53VJ000F) to control the limits of the movement.
Can someone please guide me on how to activate the sensor using labview? Please help me out asap.
This is my motor control program
(6,835 Views)
(6,806 Views)
can anyone provide me with the labview programme to test out the sensor ??
(6,800 Views)
An example could be found from Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Counter Measurements
(6,796 Views)
but i am not required to use daq to connect to the motor and sensor.. or must i really use daq in order to read the signal ??
(6,786 Views)
if you don't use daq, then, how are you going to acquire the signal?
(6,780 Views)
must we activate our motor programme in order to use the counter measurement example because our sensor is already connected to epos2..
(6,778 Views)
