01-18-2007 06:02 AM
01-18-2007 07:39 AM
01-19-2007 03:48 AM
sir
I am new to use LABVIEW 8.2 so explain clearly how to read sound signal from WAV file through software. If you have an example node send me immediately.
01-19-2007 03:52 AM
01-19-2007 08:06 AM
01-19-2007 11:17 AM
Hi chasan,
First, your DAQ card is not capable of measuring current. It measures
voltage. Therefore to measure the current you are getting back from the
coil, you will need to use a high precision resistor, measure the voltage
across that resistor, and divide the measured voltage by the known resistance
to get the current.
Are you sure that the valve coil is sending a current back out? Can you
measure the current coming out of the coil with a Digital Multimeter (DMM)?
01-19-2007 12:07 PM
And depending on your DAQ card, the analog voltage output probably only has 5-10 mA of current drive which I doubt is enough to actuate the valve.
What DAQ card are you using and what are the volatge and current specs for the valve?
01-22-2007 01:48 AM
01-22-2007 01:50 AM
Hi Ching
Thanks fro ur response
but iam measuring across a resistor only as voltage it comes around 250mV
Using PCI6040 and LabVIEW7.1
pls help me in troubleshooting
Chandirasekaran
Engineer-LabVIEW
Emerson
