how to read datas from WAV file and remove noise
sir,
           I want to read the sound signal  from WAV file,  then remove the noise from that signal and store another location.
Message 1 of 9
(3,962 Views)
Reading the WAV file is easy.  There is a function for that in LabVIEW already.  As for removing the noise, it depends on the noise.  Can you post an example of the WAV file you want to clean up or describe what the noise is that you need to remove?
Randall Pursley
Message 2 of 9
(3,949 Views)
sir
        I am new to use LABVIEW 8.2 so explain clearly how to read sound signal from WAV file through software. If you have an example node send me immediately.
Message 3 of 9
(3,938 Views)
Dear All
I require ur help in building a VI to generate a sinle pulse(not continous) and send it a valve coil to actuate and measure the coil current back(response measurement)
For the above i used analog output and input option to send the pulse and measure the coil response but i succeeded in sending pulse and actuated it(oen/cose) but could not get the coil response back(current)
 i need to to do it simultaneouisly
I request the LabVIEW community to help in this regard i will attach the vi currently iam using
pls send me some example vi's
iam using PCI6040E and LabVIEW7.1
Thanks and Regards
D.Chandrasekaran
Engineer-LabVIEW
Emerson-IA
Message 4 of 9
(3,935 Views)
Look in the 'Find Examples...'.  In the examples there is a vi called 'Read Sound File to Chart'.  Take a look at that.
Randall Pursley
Message 5 of 9
(3,931 Views)
Hi chasan,
First, your DAQ card is not capable of measuring current.  It measures voltage.  Therefore to measure the current you are getting back from the coil, you will need to use a high precision resistor, measure the voltage across that resistor, and divide the measured voltage by the known resistance to get the current.
Are you sure that the valve coil is sending a current back out?  Can you measure the current coming out of the coil with a Digital Multimeter (DMM)?
Ching P.
DAQ and Academic Hardware R&D
Message 6 of 9
(3,918 Views)
And depending on your DAQ card, the analog voltage output probably only has 5-10 mA of current drive which I doubt is enough to actuate the valve.
What DAQ card are you using and what are the volatge and current specs for the valve?
Message 7 of 9
(3,912 Views)
Hi
I am not measuring the current Directly iam measuring interms of voltage only across a resistor it comes around 250 to 350mV
more over i am using PCI6040E card and LabVIEW7.1
Pls help in trouble shooting
Chandirasekaran
Engineer-LabVIEW
Emerson
Message 8 of 9
(3,893 Views)
Hi Ching
Thanks fro ur response
but iam measuring across a resistor only as voltage it comes around 250mV
Using PCI6040 and LabVIEW7.1
pls help me in troubleshooting
Chandirasekaran
Engineer-LabVIEW
Emerson
Message 9 of 9
(3,892 Views)
