how to read *.dat type file
Hallo!
Can anyone help me with reading *.dat file using labview functions. Previously I've read them via matlab script, but after compiling to executable I could not read *.dat files. It might be because I'm working on LV 6i and in order to be able to read via matlab 6.5 I've paste matlabscript.dll from LV 7 to the main 6i place. However now I want to load this dats by using LV function and I can not achieve it.
I've already tried to use some examples from the help base and it doesn't work. There are slightly more then 2 milion samples in one coloumn in tis file.
Can anyone show me how to do that? I will appraciate
thanks
michal m
Message 1 of 9
(8,431 Views)
I'm sorry I've enclosed wrong file.
to make myself more clear I also enclose two vi
One is reading this dat file via matlab script and it works correctly.
The resault is one column wektor with 2097150 elemnts.
The other is reading using LV funktions from advanced pallete, and it doesn't work.
I receive error number 71 that means datalog type conflict.
I know from matlab that the data in that wektor are cardinal numbers, so I input to open file function this type of datalog.
Please help, I must not use matlab script because after making it executable reading via matlab doen't work, or it might be that someone can help with it.
I appriaciate any suggestion
thnaks
Message 2 of 9
(8,411 Views)
a *.dat extensions is generic, it does not specify a distinct format. Your matlab script seems to read each byte and outputs it as DBL number. This seems like a waste, because you are using 8 bytes to represent the information contained in a single byte.
If you want the same output as from your matlab script, simply read it as string, then convert it to byte array, (then convert it to DBL if needed).
Are you really sure the matlab script gives you the right result?
Message Edited by altenbach on 05-28-2005 08:56 AM
Message 3 of 9
(8,409 Views)
From the pattern in the data, it would make much more sense if read as big-endian I16 array with 1048575 array elements.
Compare the two outputs in the attached image (only first 200 points shown).
Upper graph: the way you read it as 2097150 size U8 array.
Lower graph: the same dat file read as 1048575 size I16 array.
What kind of data is this?
Message Edited by altenbach on 05-28-2005 09:14 AM
Message 4 of 9
(8,402 Views)
Thank you Altenbach. You right that U8 type graph doesn't make sense.That was brilliant notice about data type. I didn't know that matab assumes by default uchar datatype from dat file.
Now I can manage to read this file using LV functions, but another problem araised.
I've figure out that data type is U16. When I read using LV functions data differs completely from the data the way matlab reads. BTW it looks again very strange. Changeging from U16 to I16 makes the signal look more likely real, but it's still different from matlab.
Picture shows:
Upper: LV graph I16 (U16 is more likely your upper graph)
Lower: Matlab U16 graph wich is correct !!!
I'm realy confused
michal m
I apraciate any suggestion
PS don't get mad about my spelling
Message 5 of 9
(8,372 Views)
Here is also vi from the picture from the last post
Message 6 of 9
(8,375 Views)
buldog,
Use a U16 and the 'Swap Bytes' function (Advanced pallette>>Data Manipulation) and you'll get what you want I think (see attached jpg). It's a Big Endian vs Little Endian thing.
You may want to take a look at Writing Binary Files with LabVIEW That Can Be Read by Other Applications even though you're reading.
Fading out. " ... J. Arthur Rank on gong."
Message 7 of 9
(8,357 Views)
LabVIEw is always big endian (on any platform), but most other programs are little endian on intel machines (windows). See also the link Donald posted.
Your particular code still has a few bugs. Since you are reading U16, the number of data points is half the number of bytes in the file. You are trying to read twice as many and always get Error 4 (EOF encountered). To avoid this error, you need to divide the bytes by two for reading. Also watch out for correct representations, your record(s) indicator is I32 instead of U16, causing unecessary extra memory usage. ... and don't forget to close your file when done reading. 😉
Message Edited by altenbach on 05-30-2005 09:19 AM
Message Edited by Support on 05-31-2005 08:59 AM
Message 8 of 9
(8,335 Views)
Thank you guys!!!
Now I feel much wiser 😉
michal m
PS You know that I did realy forget to close the file
Message 9 of 9
(8,306 Views)
