how to read an excel file without using ActiveX
I need to read in labview an excel file in drive format, because my application ,when ready, will be runned on a PC without Microsoft Excel, the user will update the file from drive sheets ( it's a 2D string array) So I shouldn't go through ActiveX.
To proceed quickly, I have used temprary the function " array to spreadsheet string" and do " copy paste" of the file content every time i run Labview, but it's not a practical solution, as it's not efficient that the user will everytime copy paste a very long file to execute it !
Without using ActiveX, Is there a way / a function to browse the drive file to get as an output a 2D array of strings.
Thank you in advance for your help.
Message 1 of 28
(6,874 Views)
It's not very clear to me. What's a "drive format" or "drive sheets"? Do you mean binary format files?
You don't explain why the user should copy and paste the file. Why not reading the file directly?
Paolo
Message 2 of 28
(6,860 Views)
I have read many discussions in the forum speaking about activeX tool. (For example with the report generation toolbox from ni) But, for me I can't use it for these reasons:
1.  Excel is not installed on the targed PC. (to get the ActiveX interface)
2. Even when i tried with ActiveX, I found always errors, because there exists different "Microsoft Excel x.x Object Library Version x.x" which have different methods and properties. If a costumer has an other version, it could be that it doesn't work.
Therefore I think it's better (if possible) to use Spreadsheet-files. They can be opened with all versions of Excel and used without activeX in LabVIEW..but does someone experiment with this before and give me some suggestions please !
Message 3 of 28
(6,858 Views)
Why you use copy/paste? Just go to Excel, and "save as" the xls(x) file as a TAB delimited txt (or csv, etc.). Now LabVIEW can easily read the file. This is a quick step to do.
Message 4 of 28
(6,852 Views)
I can't read the file directly because i don't have excel installed on my PC, that's why i shouldn't use ActiveX, in fact,  the file is uploaded from drive (online).
So, in order to read the content of the file, i convert it to a string and then use " spreadsheet string to array", so i'm obliged everytime to copy paste the file content to have a string then a 2D string array so i can run my program. hOwever i want to read it directly
You will find attached what i have done
Thank you for your responses
Message 5 of 28
(6,835 Views)
I already told you that you need to save ("save as") the Excel file as a TAB or comma delimited text file, I imagine this should be done at the source PC (where you upload the file to the "drive").
It is very easy to read a simple text file using LabVIEW, you do not need to manually copy/paste the content as a string to a string control!
Here is how you can do it using comma delimited csv file: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LdGSAU
Message 6 of 28
(6,829 Views)
Definitely, you cannot read an Excel xlsx or xls file without Excel. It contains a lot of binary information about cell formats, formulas and so on.
Excel is absolutely needed to export such a file to a readable, (usually) tab delimited text file. Then, you can use Read spreadsheet file to load data into LabVIEW.
Paolo
Message 7 of 28
(6,827 Views)
Look for an (open source) .NET library for open documents.
https://www.google.nl/search?q=office+document+.net+library+excel
Trick is to find one that has a build assembly (.dll), because you can't statically link against code...
Message 8 of 28
(6,816 Views)
I see two options:
- Use a 3rd party tool (like XLR8) to read Excel files without needing to install Excel. You find XLR8 using VIPM.
- When you have to deal with XLSX files ("modern" Excel file formats) you can easily UNZIP them (infact they are just a ZIP container). Then you can parse all the Excel data content, which is XML coded…
Message 9 of 28
(6,814 Views)
@GerdW ha scritto:
I see two options:
Sure today you can find a software component for almost any task. However it has a cost. Parsing XML has a development cost too.
samehA should consider which is the best cost-to-benefit way to go, whether buying an Excel licence or something else.
The OP
Paolo
Message 10 of 28
(6,801 Views)
