how to read an array from .net by reference in labview
in Labview, I Integrated with .net DLL, which has a function that returns an array of integers,
this function takes an initialized array by reference to be filled.
so, my problem is I can't do it with LabVIEW [I'm totally a beginner].
I need to retrieve this array and display it.
I attached the .net code and LabVIEW node
Message 1 of 10
(2,871 Views)
any idea?
Message 2 of 10
(2,816 Views)
All you did so far is attach two pictures.
Message 3 of 10
(2,794 Views)
I tried to display it on the array but the values didn't come to its still zeros.
so this is my question bcoz I don't know how to do this.
Message 4 of 10
(2,747 Views)
That .Net code looks strange to me. It seems that the parameter is really a function??
Rolf Kalbermatter  My Blog
Message 5 of 10
(2,733 Views)
I would assume you either simply initialize an array and wire it to the input, or you need a "to.NET object" in between.
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 10
(2,715 Views)
its an interop DLL the original function written in c++ with "SafeArray(int)*" Argument
Message 7 of 10
(2,679 Views)
the problem is there is not input in the node
Message 8 of 10
(2,675 Views)
this is how I can read the array in vb.net
this is what shown in dotpeek
Message 9 of 10
(2,660 Views)
So how exactly is it failing? Is there an error that occurs?
My first question for you would be are you certain that the method signature is correct? A parameter with the out keyword is not required to be initialized prior to being passed to the method. Seeing "Int32[]&" when you hover over the terminal indicates that LabVIEW is correctly identifying it as an integer array. If the signature is correct, this should function properly.
If the array truly must be initialized first, then the parameter should be using the ref keyword.
Take this example class:
    public class Class1
        public static int GetSomeArray(out int[] arr)
            arr = new int[] { 1, 2, 3, 4 };
            return arr.Length;
        public static int FillSomeArray(ref int[] arr)
            for (int i = 0; i<arr.Length;i++)
                arr[i] = i;
            return arr.Length;
Note that if GetSomeArray() did not assign a new reference to arr that it would not compile.
ref = the parameter being passed may be modified by the method, and must be initialized prior to calling.
in = the parameter being passed will not be modified by the method and must be initialized prior to calling.
out = the parameter being passed must be modified and does not need to be initialized prior to calling.
LabVIEW will not generate an input terminal for out parameters, and shouldn't really need to.
You can call the methods from the example class in LabVIEW like this. (It could get more complex if there were different data types involved, but for primitives like Int32 that LabVIEW can automatically handle marshalling of, it's pretty simple.)
Message 10 of 10
(2,631 Views)
