how to plot power vs. RPM
Hello Everyone,
What I am doing now is plotting the power vs. rpm. I have plotted the rpm vs. time and power vs. time. I have two while loops for each parameter because one while loop uses the old DAQmx setup and the other uses the DAQ Assitant to get the power. I am not sure on how to plot the Power vs. RPM.
Please find below a picture of the block diagram. I have used the excel method but I want an XY graph where the X is RPM and the Y is power output. I have looked at examples on how to use XY graph but were not of use.
Any help would be appreciated.
Marwan
Mechanical Engineer
(3,321 Views)
Hi Marwan,
did you look at the context help for an XY graph?
It looks like that:
It says: bundle an array containing X values with an array containing corresponding Y values to a cluster and wire it to a XY-graph...
You may build an array of plots too...
(3,289 Views)
