how to plot constant width-- bar graph?
hi all?? I'm having a problem...
I'm having two 1D arrays, I have plotted them by using XY graph with bar graph, The probelm is i'm not able to get the bar graph with consant width.
How to get the bar with constant width...
Could any one Please through some light for my querie?
I'm attaching my VI, front panel, block diagram
Thanks in advance..
(3,822 Views)
Hi girikavali,
you need to supply data with constant gaps between x coordinates...
Easiest would be to include some more points in your data: add a point "left" and "right" to each x value with constant dx ("x-dx" and "x+dx"). Use "NaN" as y value sfor these added points...
Example:
(3,809 Views)
Thank You GredW.
Is there any programming way to do that.. I mean by using property node (or by another way) to maintain the constant bar width.
Thanks & Regards..
(3,798 Views)
Accepted by topic author girikavali
Hi girikavali,
you could do some programming to create a subVI that adds those NaN-points automatically?
(3,794 Views)
Thank you GredW..... I got it....
(3,788 Views)
