how to parse all the data of the particular tag in the xml file
Hi All,
I have a xml file, which have tags like, code,rev_num,type...volunteer.I want to parse the xml and save the all data(code,rev_num...) of the tag <type>unknown </type>in a text file. I tried to use a Match node vi but I not geting the output i need.attach is my attempt , can anyone suggest me or help me out.(Sorry Cant attach the xml hence i saved it as an text file.)
Ankit G
(3,028 Views)
Do you want to extract all the data with type='unknown'?
Then try the XPath like this:
resource[type='unknown']/code
TailOfGon
Certified LabVIEW Architect 2013
(3,013 Views)
Yes I want to extract all the data of the type = "unknown", I tried Xpath resource[type='unknown']/code but it didnt work , I still getting all other data of different type .
Ankit G
(3,001 Views)
Accepted by AnkitG
You need to replace all instance of "resource" with "resource[type='unknown']". Did you do it?
TailOfGon
(2,999 Views)
Thanks a lot changing all instance of "resource" with "resource[type='unknown'] did work.
Ankit G
(2,993 Views)
Glad it worked!
TailOfGon
(2,985 Views)
