how to modify input range (DAQ assistant) with a numeric control ?
hello every one
I am currently working with the NI USB-6218 acquisition card.
I would like, in order to acquire a signal, to be able to choose the input range of the DAQ assistant with a numeric control ( and not by opening the DAQ assistant window ) (like the "number of sample" and the "rate" entry...)
Is it possible and if yes, how ?
Thanks so much in advance for your answers !
(3,372 Views)
Accepted by guyua
You can't with the DAQ Assistant so right click and select 'Generate NI-DAQmx Code'. Then you can edit the subVI that does the setup.
(3,370 Views)
thanks for your answer !
However, yhen i convert the DAQ assistant, I ge this error: "The polymorphic subVI is broken. You must fix all errors in the polymorphic subVI before this VI can run."
Even if I found the input range entries, I can´t launch the acquisition anymore. Have you an idea about how to solve that problem ?
Thank you very much !
(3,361 Views)
I don't know since you did not attach either the original or broken VI.
(3,356 Views)
hello
sorry I forgot it. but after spending a few hours on the problem this morning, i solved it 🙂 Apparently, I corrupted the general DAQmx assistant last friday. By restarting my computer this morning, this issue was solved and I was able to transform the constant into command for the input range.
Thanks a lot for your help !!!
Guyua
(3,338 Views)
