how to modify about...
Hi all...
i need a big help here... during i write my program with labVIEW 7.1 express... i had modified a VI call "export waveform to spreadsheet file..." but after i tested my program, i found that result was not i want! and i also can't found the problem out...
hope someone can help me~ 😞
below is the VI that i modify...
(2,834 Views)
here is a result file after i tested my program...
as you can see... got a problem in the first data saved, the VI can't write the date/time and sample per second completely...
what i wish to ask is "is it possible to make all the data in the file link together? i mean in the "index" after 99 in the first second of the saved file then it straight away jump to 100, 101,102 and so on... whitout appear data/time & sample per second again in each following hundred data...
Jaxx
(2,830 Views)
Hello @,
The header infromation in your VI is tied to a boolean input. Setting the boolean input, Header? (write header:T), to false after the first execution should prevent the date and time from appearng again.
Good luck with your development,
Matt F
(2,793 Views)
what i need not just about the (Write Header:T) only... but gonna modify the VI that i posted... i think i already solved the problem...
by the way, thanks for your reply... Matt F
Jaxx 🙂
(2,779 Views)
