how to measure multiple inputs with a NI 6220 card
I'm currently playing with a NI 6220 DAQ card. I've found how to measure one input frequency using a counter but I've got 6 different inputfrequencies which I want to measure and only two counters. I would like to measure my 6 inputs without having to switch from one input signal to another.
How can I do this?
Gert
(3,114 Views)
What's the frequency you need to measure? The analog inputs only have a 250 Ks/s sample rate but if your frequency is no more than 1/2 this, you can acquire an analog signal and use a function like Extract Single Tone to determine the frequency.
(3,096 Views)
its 22kHz I have to measure.
(3,090 Views)
Using the analog inputs for all 6 at once would not work since your effective sample rate would not be high enough. You could sequentially use two separate tasks of 3 channels each or use the two counter inputs and a single analog input task with 4 channels.
(3,082 Views)
I don't want to measure all 6 channels at once. I just want to prevent the use of extra hardware to switch from one channel to another.
What i like to do is connecting all 6 channels to my DAQ card but only measure one channel at a time.
(3,064 Views)
Then just use 6 DAQmx Read tasks or 6 separate DAQ Assistants sequentially.
(3,052 Views)
