how to make a RESET button in labview ?
It does not make a lot of sense to add to an old thread and just repeat the subject line in the body of the post. (You did the same here). Since the question has been discussed in detail, please clarify what else you need.
Message 31 of 32
(634 Views)
Reset for Windows is a DOS command. It is: Shutdown –r –t 00
If you want to delay the reset, replace the ceros with a number = seconds
Example: Shutdown –r –25 will delay 25 seconds, then restart.
To shutdown the PC the command is: Shutdown –s -t 00
In Labview you should use a RUN vi and feed it with a string containing the command.
Good luck there.
Message 32 of 32
(611 Views)
