how to maintain data in a boolean array
You should be using an event structure to handle the change to the value of the numeric control. Then do your comparison. I'm in the middle of something else, so I would ask you to try setting it up yourself.
Message 11 of 28
(1,774 Views)
Accepted by Gombak
Not sure but check whether the attached VI meets your requirement!
______________________________________________
Kudos are welcome
Message 12 of 28
(1,767 Views)
Gogineni Thank you so much for ur help
It solved my problem
God bless you
Message 13 of 28
(1,755 Views)
Thank you everybody for your help
Message 14 of 28
(1,753 Views)
when I saw your post
formatted in the center
I want a haiku
justification
lead to misunderstanding
I am dissapoint
Jim
Message 15 of 28
(1,752 Views)
So how is Gogineni's post the solution to your problem when that was exactly what I told you to do in the first place back in message #2?
Message 16 of 28
(1,733 Views)
<----- Banging head on desk.....
Message 17 of 28
(1,714 Views)
You are right ....
But I am new in Labview and I didn't understand your reply  well .....
that was my first post
take it easy
Message 18 of 28
(1,700 Views)
Message 19 of 28
(1,655 Views)
"The boolean array you use to initialize the shift register has only five elements" where is that 5 elements ... I mean If I can control
the number of the elements in the shift register I would make it 8 ... But how can I do that ?
There are 8 elements in the Boolean and 8 elements of the numeric control array as well
Message 20 of 28
(1,648 Views)
