how to increase data acquisition speed ?
the graph with data is nothing unique, you see a straight line at the voltage value that the photodiode reads.
how can i change the dynamic data, and to what shoould i change it?
Message 11 of 12
(441 Views)
You get rid of the dynamic data type by getting rid of the express VIs. If you use the DAQmx VIs directly you can select either an array of double-precision floats or a waveform.
What is the dynamic range of the signal that you are trying to measure? If your DAQ is set to +- 10 and the signal is only 0 to .25V, it would probably be indiscernible.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 12
(415 Views)
