Smaller overview of the waveform graph
Hello
I need a smaller overview of the actual waveform graph just to know the exact position where I am, when I zoom in and out of the graph for measurement purpose with a position cursor. Could anyone please help me how to do this. Thankyou in advance
Regards
Pratheek
Message 1 of 10
(3,961 Views)
I would use the range properties of the zooming graph to set the position of the cursor in the overview graph.
Snipet:
Screenshot:
Could you send the data file, which is imported, please, if you need more help?
Message 2 of 10
(3,927 Views)
The actual mechanism can be different, depending upon exactly how you want to do it, but the basic idea is as follows:
  1. Create a new graph below your primary graph. This is your overview graph.
  2. Use scale range change events on the primary graph to trigger redraws of your overview graph
  3. Use three traces (with timestamps) on the overview graph to show the before, selected, and after portions of your waveform in different colors. Scale the number of traces as needed if you get both X and Y selection.
Much of this is shown in the demo code for Generate and Display in Managing Large Data Sets in LabVIEW. This is the technique used by SignalExpress.
Take a look at the demo code and let us know if you need more help.
Message 3 of 10
(3,923 Views)
Hi ghighuphu
Thanks for the reply. I tried this method but its not working. Coming to the data file, Actually I'm working on a TDR oscilloscope. I need to compare the graph between a failure device  with a good device. I dont have any actual waveforms from the oscilloscope so i'm just trying with sine and triangle wave and later on i'll replace the "simulate signal" block with the instrument driver. i'm fairly new to labview. could you please help.
Regards
pratheek
Message 4 of 10
(3,881 Views)
Hi
When I'm trying to use  scale range change events for the waveform graph i'm not able to move the cursors at all. Could you please tell me how to do it. Thanks you in advance
Best Regards
Pratheek
Message 5 of 10
(3,875 Views)
It is working for me, see and run the attachment.
Your only WHILE loop waits for an event, so, to zoom and move the cursor (during that wait time), you have to build the zooming code in a separate parallel WHILE loop.
Message 6 of 10
(3,870 Views)
Could you please save it to Labview 10 and post it again
Message 7 of 10
(3,864 Views)
Accepted by topic author pratheek
Sure, here you go.
Message 8 of 10
(3,859 Views)
Thanks alot........ It works exactly how i need
Regards
pratheek
Message 9 of 10
(3,857 Views)
You are heartily welcome!
Message 10 of 10
(3,852 Views)
