how to have a continuous loop for specific time
hii
how can we run a loop continuously over and over for a specific perioed and loop should terminate after that period.please have a look at the attached prog and suggest me wt to do.in this prog i want to run part 3 continuously for the time specified by Exp.step .
thank you
(4,626 Views)
See attached, this is a loop which will terminate after a maximum alloted time (timeout) OR a maximum itteration, which ever is first.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,615 Views)
In LabVIEW 7 and above there's also an Express VI called Elapsed TIme. It's really simple to use. Just enter a specified elapsed time, and it outputs values such as whether the time has elapsed yet (T/F) or how many seconds have elapsed. Use the Elapsed Time boolean value to terminate your loop.
Message Edited by Jarrod S. on 07-25-200609:49 AM
Message Edited by Jarrod S. on 07-25-2006 09:50 AM
Jarrod S.
(4,611 Views)
Or simply use the "Elapsed time" express VI. (It is in the express...execution control palette). 🙂
(Don't forget to also add a manual stop button in case you need to stop early for some reason).
EDIT: I see Jarrod was a bit faster 😉
Message Edited by altenbach on 07-25-2006 08:03 AM
(4,602 Views)
