how to give command to the command prompt.
I have tried to give command in both standard input and command line inputs of system exec.vi that work on directory specified in working directory input. But  I am unable to compile the command. I followed the tutorial given in below link...
How Do I Execute a Windows Command in LabVIEW? - National Instruments.
Can anyone suggest me what to do?
(2,801 Views)
Accepted by topic author kimhyun
You did not quite follow the instructions since you are not sending a \r\n. You aren't sending even a \r though you probably think you are. Change the constant to '\' Code Display. It works for me when I remove the working directory path since I do not have those folders.
(2,788 Views)
By sending termination characters also, its not working for me.
(2,770 Views)
You are still in normal display which means you are sending a backslash then an "r".
You didn't follow Dennis' directions about changing your constant to \ display.
(2,765 Views)
I got it. Changed the display now. Thanks for your suggestions...
(2,762 Views)
