Unable to access to VI using web browser without using run time engine through G Web server
http://zone.ni.com/devzone/cda/tut/p/id/7503
It was stated "The G Web Server is an HTTP server you can use to run VIs on the Web without using plug-ins or a run-time engine. You also can run CGI applications and publish HTML and other documents to the Web."
Does it means that I could accesss to the embedded vi using a web browser from a remote pc without any plug in or run time engine? I am not able to access to the
embedded vi without run time engine.
Message 1 of 1
(2,268 Views)
