how to get smooth data
My reply #2 mentioned the same points at Altenbach's most recent reply #10.  I think the OP is waiting for us to hand him the solution, rather than his doing the work (or maybe I'm just getting cynical ...).
Message 11 of 18
(2,016 Views)
Hi all,
So i get rid of all DDT and made code  easiest at in can be.
Still have problem witch filter it looks like is scaling my value, don't know why.
Co question is where is the problem ? myby filter do not like negative value ?
Message 12 of 18
(2,003 Views)
Hi pablo,
No.
See this:
Read a fixed amount of samples.
Set a reasonable lower cutoff frequency!
You still need to improve this VI as it is not recommended to collect (large) data in evergrowing arrays…
Message 13 of 18
(1,998 Views)
For continuous recording, it often makes more sense to use a Chart instead of a Graph.  A Graph shows a fixed amount of data, from the beginning of the data.  A Chart also shows a fixed amount of data, but from the end of the data.  Thus if your Graph and Chart were 5 seconds wide, and you were sampling data at, say, 1kHz, both the Chart and Graph would show a plot starting at the left and moving to the right for the first 5 seconds.  After that, the Graph wouldn't change, but the Chart would, depending on its "mode".  The default "Strip Chart" mode would have the points slide to the left, with the most recent data appearing on the right.  There is also a "Scope" mode where it looks like an Oscilloscope, the new points "sweeping" from left to right like an oscilloscope.
Message 14 of 18
(1,993 Views)
HI GerdW
How did You manage to make this connection? is not working for me.
Message 15 of 18
(1,970 Views)
right-click...concatenate inputs
Message 16 of 18
(1,968 Views)
still not working ...
Edit:
I figured it out
Message 17 of 18
(1,955 Views)
Because your shift register is still defined as 2D array. You cannot concatenate if the two inputs have different dimensionalities.
To fix, temporarily wire a empty 1D array to the shift register from the outside, then set the "build array" to concatenate and things should clear up (There are many other ways to fix it)
Message 18 of 18
(1,947 Views)
