‎10-23-2019 09:11 AM
I am currently working on the generation of Sine PWM for the inverter switching control, so I need to know how to generate Sinusoidal PWM in FPGA mode in LabView2015, through Analog Output NI9263 I want to see the output
‎07-27-2021 06:36 AM
Did you completed this task? I need guidance on this, How to generate sinusoidal PWM in labview FPGA
‎07-27-2021 06:41 AM
Hi yuvi,
Most often you just need a sinewave and a sawtooth signal, as described here.
What have you tried and where are you stuck?
‎07-27-2021 06:45 AM
Thanks for your fast reply.
I am working on myrio 1900. I want to generate 100 kHz squre pulse(PWM) by comparing triangular and sine waveforms, then which pin I have to use to take output ( to check in DSO)
‎07-27-2021 06:47 AM
Hi yuvi,
You need to use the pin related to the output channel selected/configured in your software!
