how to find x axis value corresponding to a given y axis value in a graph
hi all,
 I have a gaph that has a 2d array of power intensity on its y axis and wavelengh on x axis. I need to find the x axis value corresponding to the maximum peak of the graph. I have found the value of y axis(named max value in vi) corresponding to the maximum peak but I am not able to find the corresponding  x axis value. Can anyone please tell me how to find that. My vi is attached here.
Message 1 of 14
(7,558 Views)
Please make your front panel a reasonable size before attaching and please make sure your graphs have some typical default data.
Message 2 of 14
(7,534 Views)
Hi shivy92,
By looking at your VI, I guess you use Array Max & Min VI to find the maximum peak of the graph. Within that function there is an output node call "max index(es)" where it will give you a location of the maximum value.
From there you can use that index value to get the X axis value you have mentioned.
Hope this help
TuiTui
Message 3 of 14
(7,481 Views)
Use WDT Get XY Value DBL http://zone.ni.com/reference/en-XX/help/371361K-01/lvwave/get_y_value/#parent
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 4 of 14
(7,447 Views)
I tried doing it that way. I made the max index as the input to an interolate array with x axis values, I got a value but it s not right, infact it is nowhere close to the required value. Is there any way I could use the peak detector to find the x axis value corresponding to the maximum peak?
Thanks.
regards.
Message 5 of 14
(7,376 Views)
I tried using WDT get XY value too, but the problem here is that it only takes analog waveform as an input. It is not accepting my XY graph as an input. Is there any way I could use my XY graph as waveform in node??
Thanks.
regards
Message 6 of 14
(7,371 Views)
Thanks.
regards.
Interpolate array? Index array!
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 7 of 14
(7,367 Views)
hi,
I have attached my vi again. The input array is actually data from an imon. I have attached the sample data here.
thanks.
Message 8 of 14
(7,365 Views)
I have tried both index and interpolate array, but i am getting the same wrong answer.I am wondering if there is any other way of finding the x axis value for maximum peak.
thanks.
Message 9 of 14
(7,357 Views)
We don't have your image drivers. Please run the VI until the image data array has real data. Stop the VI. Right-click the array and "make current value default". delete all the imaging and file IO stuff, save the VI under a new name, and attach it here.
Message 10 of 14
(7,347 Views)
