how to find thermocouple type progromatically
Hello all,
Is there a way to progromatically get the channels set thermocouple type? I ask becasue i want to write the thermocouple type in my tdms log.  I assume if possible it is a property node function, but i cant find it.
Thanks for any advice.
-Matt
(3,524 Views)
Accepted by topic author Wolleee
The property node you are looking for is the Analog Input:Temperature:Thermocouple:Type in the DAQmx Channel Property Node. If you cannot find it, it may be because it is a Device-specific property, thus you should configure the filter setting of the property node to show all attributes or select your specific device which supports a thermocouple input
(3,504 Views)
When you write this to your TDMS file be sure and write it as a property of the channel you are logging, you don't need to log it as a new channel.  Basically values that don't change, and are a single value should be a property, things that have multiple samples should be a channel.  I've seen too many people try to write properties as channels and end up with huge files that Diadem can't do much with.
(3,493 Views)
Thank you for the advice and hooovaahh im working on that portion of the code.
If you i have different thermocoupl types in the same task how would i get the thermocouple type for each one?
-Matt
(3,470 Views)
You would have an array of channels that you would use the property node on each.
(3,448 Views)
