how to find the mean of rows and columns matrix
Here you go.
uday
Message 11 of 16
(2,570 Views)
sorry but i want to calculate the center mass of the matrix for element '1'
Message 12 of 16
(2,562 Views)
Accepted by andisheye20
Did you enter 1 in element?
uday
Message 13 of 16
(2,561 Views)
This code should work:
The result is 0-indexed, so change it if you need to.
How it works:
1. Read in the sample array
2. Loop through every row, and pass the current row index into another for loop, call this i
3. Loop through every column of the current row, the index is j.
4. If the element at i, j is equal to the search element, index it out using a conditional indexing tunnel.
5. Concatenate all indexed tunnels, which essentially builds a master list of all the rows/columns where we found the search element
6. Calculate the mean index for both.
I got a mean row of 3.17, mean column of 4.52
Message 14 of 16
(2,548 Views)
For the centre of mass you need to consider only those elements that are '1'.
So take the coordinates of all of those '1' elements, and calculate the mean of the 'x' and 'y' coordinates.
As an exercise for yourself, try recreating this:
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 15 of 16
(2,531 Views)
...and if Altenbach were online he would probably suggest using complex numbers:
Message 16 of 16
(2,526 Views)
