how to find all points inside the circle on a smith chart?
Dear all,
I am plotting a circle on a smith chart. I have only an array of border for that circle. I am wondering if there is away to find the whole points inside that circle on a smith chart(X and Y)? Thanks in advance
Azam
(4,092 Views)
Accepted by Al-rawachy
Points where sqrt((x-x0)^2+(y-y0)^2) < radius where x0 and y0 are the coordinates of the origin of the circle and radius is the radius.
(4,060 Views)
Are you making your own smith cart or are you using the Smith Plot built into LabVIEW?
In any case, operate on the data going to the chart. The data going into the Smith Plot is an array of clusters, and each cluster contains two elements. The first element is r, so compare that.
It would help if you could show us a simplified version of your code. Your description is too ambiguous.
(4,018 Views)
Thanks for your feedback.
kindly have a look for the attached vi(s). I have deleted some loops and wires which are out of scope of my question. By the way, I am using a cluster of a smith chart and you can see the circle is drawn on a smith chart and a big portion is located outside a smith chart. So. can I get only the points which are located inside the circle?  Thanks in advance
Azam
(3,992 Views)
Hi all,
I just want to update my query. Any advice? Thanks in advance
(3,950 Views)
Hi ,
Sorry, I didn't understand you when you wrote this equation.
after little time surfing the net, I understood what you have written
https://math.stackexchange.com/questions/198764/how-to-know-if-a-point-is-inside-a-circle
Best regards
(3,927 Views)
