how to find a string different of "off"
I have an array of strings and I need to know the index of anything that is different of the string "off".
The function Search for 1D Array can return me only the index when find something, and not the index of the string that is different of this... Is there any function for that?
For example, I can have an array like (off, off, off, standard), and I need the index 3 for the string standard.
Thank you,
Thais
Message 1 of 12
(4,079 Views)
You could use the conditional loop terminal if you have LV2012.
(right click on the loop terminal > Tunnel mode > Conditional)
Message 2 of 12
(4,070 Views)
Accepted by topic author thsmarques
Just re-read the question and realised you want the index:
Message 3 of 12
(4,069 Views)
something like this should work
good luck
Message 4 of 12
(4,064 Views)
how about this try..
LV 8.0, 8.6, 2011,2012,2013 WinXP
Message 5 of 12
(4,056 Views)
You can still optimize (just for fun)
Message 6 of 12
(4,053 Views)
Watch out, in your case selector Off use a capital "O".
Ben64
Message 7 of 12
(4,030 Views)
... unless the case is configured for "case insensitive match" 🙂
Message 8 of 12
(4,021 Views)
Thanks for the tip, actually I never realized this option exist.
Ben64
Message 9 of 12
(4,013 Views)
And how exactly do you tell from looking at the code whether or not it is Case Insensitive?  (In the snippet it is not.  Smiley Wink ).  The answer is, you can't.  It really cheeses me off when I have to resort to a right-click menu to determine how a piece of code is going to behave.
If it were me I would ditch that option.  That might be too hardcore for some, so at least make it obvious via a glyph or something what the behavior is.  I never use it, instead I drop a To Lower Case before the Selector.
Message 10 of 12
(3,999 Views)
