Showing results forĀ
Search instead forĀ
Did you mean:Ā
how to do numeric integration
I am trying to do inegration of an exponential function between two limits  but I am getting wrong results
Can anybody help me
thanking you
augustin
Certified LabVIEW Developer
(5,315 Views)
If you are trying to integrate an array of data, you should use the numeric integration.vi (in Mathematics> Integ & Diff);or the Uneven numeric integration.vi...
Chilly Charly    (aka CC)
(5,311 Views)
thanks a lot
it is working..
is it possible if data is not in arry form
(5,308 Views)
The integration can be done on the fly using the equivalent function from the point-by-point subpalette (in Signal processing > Point by Point...)
(5,299 Views)
Hi there, if you have points coming at a regular interval and that you have a LabVIEW full or professional, you can also use the point by point function. This basically accumulates the point into an array (internal to the function) and process your data.
This function , and many others, can be found under  Signal Processing >> Point by Point. The palette at that place looks really similar to the "normal function", except for the small symbol at the bottom of the menu ..->..
I hope this helps
Matthieu
(5,294 Views)
