how to display tex (alarm) depending on value store in memory of PLC (0 to 31)
Hello every one
i stuck to display fault message of inverter. there is memory in PLC which store fault code # of inverter as 0 ot 31. these 32 value in memory represent specific fault which i want to display on labview front panel. how can i compare these code to display alarm
let say memory has value "18" it mean inverter overvoltage fault and so on with every value 0 to 31 represent different faults.
please help me
Thanks in advance.
(1,715 Views)
Accepted by topic author Asif138
Hi Asif,
Create an 1D string array of strings with 32 elements and put the error description into the corresponding elements.
When you read your error number you simply use it as index into this array…
In my experience PLCs use 32bit (or 16bit) entities (aka bitfields) with each bit having its meaning. Does your PLC really store an integer number from 0-31 instead?
(1,711 Views)
Thanks for replay
yes my plc memory store integer which is 0 to 31 number.
 i explain more about that like if
memory have value 1 front panel should display "OK
memory have value 2 front panel should display "not OK
memory have value 3 front panel should display "check supply
memory have value 4 front panel should display "check input
memory have value "5 front panel should display "check output
i hope i explain it.
thanks
(1,683 Views)
Hi Asif,
So please use my suggestion in message #2!
(1,681 Views)
