how to display date on the graph
Iam having a VI which consists of XY graph.I would like to display the system date on the X-axis of the graph.How can i do this.
(2,696 Views)
Create Property Node of X-Y Graph and select XScale->Name Label->Text and insert there your system date
(2,693 Views)
If you want the X axis itself to be a date (or time) axis, you need to build your data array for the graph with the time values for each data point. Then, right-click on the X axis and select "Format & Precision" and select "Absolute Time" on the left.
___________________
Try to take over the world!
(2,684 Views)
Thank you very much for ur answere.It helped me to solve my problem.
(2,674 Views)
