how to display data receive from arduino in labview?
hi .I am a beginner in LabView. i read forum discussions to find some solution to my project .
my project is about wireless transmit & receive voltage value .The data receive should appear in lab view not in the serial monitor arduino.
(6,606 Views)
Accepted by imtheperson97
Hi person97,
Do you know this website?
Well, LabVIEW also comes with a huge library of example VIs. There are also examples on serial communication…
First point: switch off the serial monitor. (There can be only one accessing a serial port!)
Then: when trying to read just one byte from the port you will never read the whole message of your Arduino.
- As you include some EOL chars ("End of line") in the message sent by the Arduino "Serial.PrintLn") you should try to read a "big" number of bytes (like "99"): VISARead will automatically stop at the EOL char as you have configured this behaviour with the ConfigureSerialPort function.
- Setting a timeout of 100s is senseless: in case of a problem you do NOT want to wait for your program to react on your inputs for nearly 2mins! Set a shorter (reasonable) timeout - and handle timeout errors in your code!
But then again: start with the example VIs coming with LabVIEW. (A note on them: they use the BytesAtPort function: please don't use this function for your task. It will not help you here and you don't need it!)
(6,592 Views)
What's the problem in your program?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(6,591 Views)
the problem is i just want the labview to receive voltage signal by wireless and display value in waveform. like exactly the same like oscilloscope .Smiley Indifferent . i need a proper guide how to works this out Robot Sad
(6,556 Views)
thanks for the good informationSmiley Happy. i will think it wisely Smiley Happy
(6,548 Views)
Arduino D1 WeMos with LabView
Hey,
I want to build a project that gets information from the "Temp102" sensor connected to the D1 WeMos Board.
This board sends the information received from the sensor via WiFi.
I want this information that sends to the computer that has the LabView software and it will display the temperature in a termometer.
I have a program that I found in one of the sites that does what I want but with one problem!
The program is written for module Esp8266, which is connected to board Arduino Uno and therefore has different classics.
I need help converting the classics of module ESP8266 to relevant classes for Board D1 WeMos (This board has ESP8266 but it is built-in so there is no need to set it up in the program).
It's important to note that I tried to change it and make a "mix" but without success.
I would be happy if someone could check in the program what should be changed, which orders should be replaced?
(I believe it's 2 minutes work for anyone who knows)
Thank you very much for your help !
I appreciate you very much !!
I attached the programs (for arduino and for labview).
(6,478 Views)
