how to display a string in menu ring indicator
Hi
i have a menu ring control, i need to display all the updates of control button additionally with some strings
Message 1 of 26
(4,222 Views)
You will need to provide a better explanation of what you're trying to do. Updates of what control button? What strings? Where are these strings supposed to go?
Message 2 of 26
(4,220 Views)
Thanks smercurio
I have menu ring control button with few options,whenever i select these options it needs to be dispalyed in  an indicator(ring indicator, need to display all the selections). Along with the options i have selected in the ring control button i like to add some string,so the final display is the addition of the ring control button value and the string.
Message 3 of 26
(4,218 Views)
Hi Veeru,
i don´t really understand what you mean? Can you upload a picture of it. To add some strings to an enum you can use a property node.
Mike
Message 4 of 26
(4,216 Views)
To display the selected item text into a separate string indicator you use the RingText.Text property.
To add an item to a ring you use the String[] property:
Message Edited by smercurio_fc on 06-29-2008 12:15 PM
Message 5 of 26
(4,213 Views)
Mike
I ahve attached the vi,as in the code i have aring control, the string indicator displays the option selected in ring control ,in the display i need all the updates(like ring control button)
Message 6 of 26
(4,207 Views)
Thanks smercurio
I need to have all the updates(whatever i have selected)
Message 7 of 26
(4,206 Views)
I don't follow what you wrote.  What do you mean in the above?
Message 8 of 26
(4,186 Views)
Thanks Joe
I have a menu ring control button, i need to disaplay the options i have selected in ring control (all the options i selected).
I have attached the pic of my program ,in that i am able to display only 1 selection(all the previous selections are not seen).
Message 9 of 26
(4,183 Views)
Hi Veeru,
to get all strings, use a property node with the Strings[] selection. To create a string out of it, you can use the "array to spreadsheet string" function or the "concatenate" function.
Hope it helps.
Mike
Message 10 of 26
(4,176 Views)
