I have trouble connecting Datasockets and Kepserver
I am having trouble in communicating Kepserver and Labview using Datasockets. The problem I face is the data which i write is over rided by 0 and drives my controller to switch off. Meanwhile I am able to read the data from the OPC server but my write is very unsuccesfu.. Could any help me out with this..
I have attached my file alongwith for your verification
(2,712 Views)
Hi saty,
If I understand correctly, you see the expected value at first but that is then replaced by 0.  Is that true each iteration?
I would suggest opening the DataSocket connection only once, before the loop begins.  If you add an Error Out cluster ir General Error Handler, are any errors reported?
Jennifer R.
(2,695 Views)
