how to disable MATLAB Command Window when calling Matlab Script
hi, is there any way to disable the MATLAB Command window popup when calling Matlab script? thanks.
(5,236 Views)
iam not sure but if u disable the server of matlab then might it work
(5,222 Views)
Did you try a search?
(5,207 Views)
in fact i just wanna close the command window but i still need script server running in background.
is that possible?
(5,191 Views)
Accepted by beatzerg
Afraid not. As soon as you close the window the ActiveX server closes and your script will stop working. You can, of course, minimize it using the OS. On Windows you can use the Windows API Utilities, as provided in one of the responses from the threads from the search.
(5,164 Views)
