how to create control for 12bit integer.
i want create control where i can write maxmium 2^12=4096 integer value.
Message 1 of 17
(4,503 Views)
Hi rishijha,
use an I16/U16 control and change the allowed value range in its properties…
Btw. to store the value 4096 you need 13 bits!
With 12 bits you can hold values from 0 to 4095, inclusive.
Message 2 of 17
(4,485 Views)
suppose i have 29bit number that is combination of D0 -D11 ,D12,D13,D14-D17,D18-D27 and D28.how to do this one in labview.
Message 3 of 17
(4,457 Views)
Accepted by Risuraj
Hi rishijha,
use a 32bit integer!
Computers/CPUs (usually) use a fixed set of datatypes, all of them containing multiples of 8bit (aka bytes). So whatever you want to store needs to fit into those datatypes: 12bit fit into 16bit datatypes, 29bits fit into 32bit datatypes…
Message 4 of 17
(4,437 Views)
ok i assigned like that now i want to add all bit and form 32bit.so which lab view function i can use.
Message 5 of 17
(4,427 Views)
Accepted by Risuraj
Hi rishijha,
What's the point of separating bits #0 to #28 in 6 groups? Why not keep all bits in just one integer???
Why (and how) do you want to "add all bits"? ("add" in the same way as the math "add" operation?)
Maybe you want to build an array of all bits (using BuildArray) and then convert the BooleanArrayToNumber???
Message 6 of 17
(4,424 Views)
Earlier, you talked about a "control" and you already learned how to limit the range of values that can be entered. Now, out of the blue, you start talking about "D"s. What are these, what do they represent, where are they coming from, and what is "this" you want to do?
Message 7 of 17
(4,397 Views)
these group have different meaning in my application.every time i am changing these bit value in my program.
i want to combine these bit and pass in to U32 bit numeric control.
Message 8 of 17
(4,359 Views)
HI rishijha,
What have you tried so far?
Do you already use BuildArray and BooleanArrayToNumber?
And why do you want to display the result in a control? Don't you use indicators to display data?
Message 9 of 17
(4,353 Views)
A "control" is a data source. Typically data is passed to an "indicator". Please clarify.
Message 10 of 17
(4,347 Views)
