how to create an .exe 8.6
well guys when i used the LabVIEW version 7.0 was so easy to create an .exe
but now i have the 8.6 professional
and i can't find where i have to go to create a .exe file
i want to create an .exe file for my client to test them in another pc at network!
please help me =D
thanks
(3,345 Views)
Accepted by topic author EduU
You have to create a project. At the bottom of the project is "Build Specifications". Right Click and choose "New" > "Application (EXE). In LV2009 you can once again create a exe outside of the project.
Message Edited by Gleichman on 08-21-2009 11:00 AM
(3,341 Views)
thanks mate!
you solved my problem
(3,332 Views)
I did not know that.  Thanks!
(3,311 Views)
hi,
I am getting a small problem as I have successfully made exe file of my particular vi. But as my vi is containing the write to spreadsheet.vi as to store data.
So when I run my vi(exe) in standalone computer. It shows error that cant able to locate write to spreadsheet.vi. so what I have to do exactly ....I have to make exe file of  write to spreadsheet.vi ? or something else
Any help is appreciated.
Regards
Gaurav Sharma
(3,214 Views)
If it's not a sub-vi you need to add it manually to your project to make sure it makes it to the .exe
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,209 Views)
