how to create N +/- 0.5. i want to compare N value with the N+/- 0.5 pleasde help. how to do this calc in labview
hi
 i want to comparwe N with the N+/-0.5 % . How to do tyhis calc in labview
(2,353 Views)
That does not really make a lot of sense, N is always in the range or N+/-0.5%, right?
Lets assume you want to compare if one number (X) is within 0.5% of another number (N), you could multiply N with 1.005 for the upper limit and 0.995 for the lower limit, then use "in range and coerce" to see if X is in range.
If that's not it, please clarify your question with more details.
(2,346 Views)
