06-09-2011 03:37 AM
I just created in a class some VIs for access to private data (my German translation). I'm talking about these VIs, which enable you to connect your class object to a property node to read or write private class data. These VIs are by default non-reentrant. My question is: what happens, if I try to access two objects of the same class with these property nodes? Does the second object have to wait for the first one to be read? If yes, can I circumvent this by making these VIs reentrant?
Marc
Solved! Go to Solution.
06-09-2011 07:43 AM
In theory yes. In pratice it will depend on what you are doing in the private method and the methods it calls.
Ben
06-10-2011 12:52 AM
OK, thanks for your reply.
Since the method are simple read / write actions and nothing more, making the VIs reentrant should be enough.
Marc
