how to convert numeric to hexa decimal string. labVIEW 2018
Hi sir/ma'am
     i have to convert my 5 byte of data numeric to hexadecimal, i'm using number to hexadecimal string function, but in chipscope for every byte 3 is adding  i'm getting wrong data in chipscope .\
Issue:-
 In chipscope tool i'm getting given data,but 3 numeric is adding
(2,590 Views)
Hi saikiran,
which data is your "chipscope" expecting?
Can you provide a clear example?
Does it expect a "binary string"?
(Why do you use the I8 datatype for your numerics? Any good reason?)
(2,583 Views)
Hi gerdW,
 my chipscope is expecting  any decimal (or) hexadecimal data .
   thanking you  for responding.
(2,561 Views)
Sounds like a problem on the receiving side. Or the communication. The sending seems right.
Are you using the expected baudrate (parity, handshaking, etc.)?
(2,550 Views)
@saikiranbusharaju wrote:
my chipscope is expecting  any decimal (or) hexadecimal data.
That is still not clear.  You can express a number as a decimal or hexadecimal value, but it is still a raw 8-bit value.  Or you do a conversion so that the hexadecimal values are in ASCII (I call this ASCII Hex, you can read the data in a text editor).
So where is this value supposed to be read?  Do you have any documentation on how to write to the software?
(2,534 Views)
