how to convert ascii character to decimal integer
Am sending a string of characters by USART protocol and I wanted to convert the ascii of the characters into decimal intger .. the decimal string to number block didnot work ..Also I failed to use the type cast block in this conversion .. So Can anyone help I need an fast answer asap !
Message 1 of 17
(13,035 Views)
Accepted by shrouk'13
there must be an easier way than this....
try this, rt clk constant to represent U8...
Message 2 of 17
(13,027 Views)
Your question is way too ambiguous. Show us a typical string and what result you expect from it.
Message 3 of 17
(13,012 Views)
Am sending a characters in a string .. and I wanted to convert a character like 'A' to its ascii code to be int ( to be converted to 65 ) !
Message 4 of 17
(13,000 Views)
So typecast to U8 is the answer. I was confused since you said typecast did not work.
Message 5 of 17
(12,996 Views)
But when i tried it .. it displayed an int from 8 numbers !
Message 6 of 17
(12,989 Views)
I have no idea what that means....
If you have eight characters, you can use "string to byte array" to make it into an array of eight numbers.
If you see eight numbers in the U8 indicator, adjust the display format.
Message 7 of 17
(12,973 Views)
I made an constant 'A' to the input of the type cast but the output was 8 numbers too.
How is that ?
Message 8 of 17
(12,967 Views)
How is that ?
post your code...
Message 9 of 17
(12,962 Views)
How is that ?
What did you wire to the "type input"?
What are "eight numbers"? A number with eight digits? A numeric array with 8 elements? A string with 8 numeric characters?
Message 10 of 17
(12,958 Views)
