how to convert Hexadecimal string to binary
hai,
How to convert Hexadecimal number to binary
8300000000008002 hexadecimal No. to binary
how to convert.
thanks
sasi
(23,496 Views)
This is a 64 bit number, how do you want to convert it: to a byte array, as a single i64 or u64 integer, another way?
Paolo
Paolo
(23,482 Views)
Hello developer,
you also have to define what a "binary" is! Do you want to have a boolean array or a string containing "0" and "1"?
Converting to a different string is easy: Use "Scan from string" to convert your hex string to a number and "Format into string" to get a boolean string. The format codes are "%x" and  "%b", respectively. You can also use the intermediate number to convert to a boolean array.
(23,474 Views)
First point to note - as already mentioned, the hex number equates to a 64 bit binary number, and it's only since LabVIEW version 8.0 that 64 bit integers are handled.
Presuming you have LV 8 then see the attached VI...
Important: You must wire a 64-bit integer to the "default" input of the "Hex to Number" function, if you want the function to return a 64-bit integer output, because otherwise it will return a 32 bit number by default (legacy from before LV handled 64 bit integers)
Mark.
P.S. If you don't have LV 8 then there would have to be more code involved to split the hex string into two parts, then convert the two parts before recombining into a 64 bit string..
(23,471 Views)
thanks for ur replies
i want to have hexadecimal to boolean array
i am using labview 7.1 version
thank you
sasi
(23,466 Views)
Try this vi. Note that we need to split the hex string in two parts each 32 bits long.
Paolo
Paolo
(23,447 Views)
