how to convert C code in LabVIEW
Hi there I have a quicik question.  i have a line of C code that I am trying to implement in LabVIEW and I was wondering if someone could show me how to do so.  The following is the line of code that i am trying to implement:
if ((temp = temp1 & (unsigned) 0xFFF) & 800)
       temp = temp - 4096
Where temp is 16 bit signed and temp1 is 16 bit unsigned.
This line of code is meant to perform a sign extension.  temp1 is a 16 bit unsigned number.  I am then performing logic AND with FFF to mask the first four upper most bits.  Then I am going to check to see if the upper most bit is  a one.  If it is then i am going to subtract 4096 from this number.
If someone could send me a snippet of code that could implement this line, it would be greatly appreciated.
(4,382 Views)
Is there some reason why you can't just cast the number to a different representation? Or am I misunderstanding the question?
(4,378 Views)
Let me see if I understand correctly: you have a 12-bit signed value, stored in a 16-bit value, and you want it sign-extended through 16 bits?  I think there are easier ways to do this in both LabVIEW and C.  Here's one idea:
(4,363 Views)
I think you are right with the 12bit assumption and your solution.
However, I would prefer the numeric way and thus avoid the BD constants.
(4,349 Views)
Your method does not produce the right result.  A decimal value of 4095 (-1 for a 12-bit value, 0xFFF) correctly returns -1 in my code, but returns -4095 in yours.
(4,333 Views)
It's straight forward using shifts. This gives a different output if the input is beyond 12 bits though.
(4,323 Views)
@nathand wrote:
Your method does not produce the right result.  [...]
Thanks. Your are right. My approach does not consider that the numbers still are ordered in a ring.
(4,310 Views)
