how to control speed of video file
HI,
 I want to control the frame rate  of a video file so as to play it with different speeds(eg. 1x/2x/4x) Is it possible?
 I am using Labview 8.5.I have opend WMP & have used property node :=> Class:ActiveX=>WMPlib.IWMsettings..n selected property as rate.
 but i don't know if it is frame rate or data rate or bit rate....so please help me with this problem.
  Thank you
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,861 Views)
Accepted by topic author Gak
Does this, this and this post belongs to same user? Because these posts came at a relatively frequent timings
(2,857 Views)
