how to control and monitor omron plc from labview
i am able to make the plc communicate with labview 2009 using NI OPC Server and DSC Module via ethernet but i do not now to control and monitor plc boolean data from labview.
the plc i am using is Omron CJ1M CPU11 with CJ1W-ETN21. I am still very new to labview and i hope somebody can help me out with this and give me some advices on how to proceed. it should also be noted that i cannot change the status of the tags directly from NI OPC Server itself.
Below is the simple circuit i would like to use as a starting point for controlling and monitoring plc data from labview:
22443iF884278442062D80
Thanks in advance for the help.
Message 1 of 10
(12,380 Views)
1. You need to set up OPC server to CJ1M communication following the step in  Start>>All Programs>>National Instruments>>NI OPC Servers>>NI OPC Servers Help>>Omron FINS Ethernet>>Launch Driver Help.
2. Configure I/O Server binding to NI OPC Server.
3. Creating shared variable binding to NI OPC Server tags, and use these variables inside LabVIEW program to communicate with CJ1M.
#2 and #3, please follow http://zone.ni.com/devzone/cda/tut/p/id/7450
Message 2 of 10
(12,360 Views)
Yes, i have configured the communication between plc, opc and labview with the dsc module like the tutorial. i can also monitor the change in values of the opc tags when i change the states of the switched in cx programmer.
however, i do not know how to write data to the plc from labview. by writing data, i just mean to change the status of the control switches of the ladder diagram (force on, off) hence manipulating the output of the ladder diagram.
Message 3 of 10
(12,353 Views)
1. Drag shared variable you create in LabVIEW project to block diagram.
2. Right click on it>>Change it to write.
3. Wire the value you wish to write to a shared variable.
Message 4 of 10
(12,346 Views)
i tried doing a simple write before but it still does not work. is there a tutorial/ sample vi that i can learn from?
Message 5 of 10
(12,338 Views)
Please attach the whole project include opf file (OPC server configuration)
Message 6 of 10
(12,327 Views)
ok i have included the project files and the opc file as well.
Message 7 of 10
(12,311 Views)
Accepted by topic author jacintha
You can read only from the input, cannot write.
For output, you can either write or read.
However, if you've a ladder controlling that output line.
It'll have a conflict.
Message 8 of 10
(12,252 Views)
thanks KateB. i finally can see it for myself. can write/read to output tags but can only read to input tags using datasockets. i just wondered why is it like that? could you explain it to me?
Message 9 of 10
(12,183 Views)
I had a similar problem with a Koyo DL06-DR PLC.
The solution was to build a ladder input multiplexer: the mux control bit is an internal flag. This flag gets cleared during the PLCs first scan and can be set/reset by the PC to steer where the PLC inputs would come from (either direct inputs or from PC control bits).
The outputs can be read/written anytime by the PLC or PC, so the PLC code is written using stage programming techniques, with set/reset instructions being placed only where needed.
Message 10 of 10
(11,631 Views)
