how to continuously plot data?
I am trying to plot data that is being acquired from an LVDT and a thermistor, but in my VI, apparently the waveforms plot a single value every time a new data point is acquired. The rate at which data from each instrument is being acquired depends on how often the thermistor sends data, hence the case structure determining when the DAQ device and serial port are being read...the data is essentially being overwritten so the waveforms don't show the "history" of data that I'd like to see. I've attached my code; I suspect that something in the overall structure is wrong, but this is what successfully eliminated framing errors I had reading the COM serial port. Could someone please give a tip or two to a student scrambling to finish her project on time? Thank you so much.
(By the way, I intend to eventually use subVIs to clean this up, but for now, I'm just trying to get the waveforms plotting correctly so please bear with me on the mess)
Message 1 of 10
(4,501 Views)
Where is the code ?!
I think you have to use a while loop to continuously plot the data & a shift register to show the "history" of data...
Try this out or post your code here for more help.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 10
(4,494 Views)
Hi hzenah,
What u need is to use shift register as to see history of the data points in your plot. U can find plenty of examples in the previosu discussions just look for the keyword "'shift register or history of plot"" in the forum..
Message 3 of 10
(4,495 Views)
Sorry about not attaching the code properly; I'm not sure what happened.
As for shift registers, I thought about that but in my situation, I need them from a case structure, or something like that, and I'm not sure how that would work.
Message Edited by hyenah on 05-31-2007 03:59 AM
Message 4 of 10
(4,493 Views)
Note: Put the charts inside your True case stucture
Also, since you are using charts, you do not need the 'Build array' function. Just assign a large enough ' Chart history length' value and that should do ( this you do be right clicking on chart in front panel and selecting that option from  the drop down menu)
Also look at this sample vi to understand how to plot acquired single data points on Graphs and charts
Any further doubts, do ask
Dev
Message 5 of 10
(4,485 Views)
Sorry, missed attaching the vi
Here you go
Dev
Message 6 of 10
(4,484 Views)
Dev,
Can you attach the VI in  7.1 ?
love,
lvlover
Message 7 of 10
(4,454 Views)
Message 8 of 10
(4,412 Views)
Hi Dev,
When I tried to run your VI, I got the Insane Object error. I ve to click OK, then it runs as usual. If I change the Wait time, it aooears twice.
In 7.1...
Can you try it out on your side if it is happening pmly in 7.1 ?
Please see the attached screenshot of the Insane Object error.
Message 9 of 10
(4,399 Views)
Partha,
It seems to work fine out here
Let's see if our friend 'lvlover' also experiences the same problem
Dev
Message 10 of 10
(4,386 Views)
