how to connect it??
Hello mike 🙂
I installed the software but there is no such a thing called dll or activeX but I already asked my teacher about it and he said it can work with both with no problem....
do you think that I can find a vi that already built and use it?? if not tell me the steps and be my new teacher Robot tongue
Message 11 of 26
(1,857 Views)
Hi reemon,
if there is ActiveX support for this card, you can use the ActiveX functions from LabView. Use the "Automation Open" function and create a "Automation Refnum" constant. With right click on it you can select "select ActiveX class" and "Browse". Now search for a function which sounds like it clould be from your card, or read the manual and find helpfull things. If your teacher know this function is supported it has to be documented somewhere.
Mike
Message 12 of 26
(1,856 Views)
I am doing the job now but mike if I want to try it with the dll where I can start in the labview?? cause I found a file on the cd related to my card which is MSVCP60.DLL
so maybe it will work also with dll
I attached the files that is on the CD
Message Edited by reemon on 04-08-2008 01:17 PM
Message 13 of 26
(1,851 Views)
Hi neemon,
to use a dll you have to use the "call library node" and load your dll into it. If you have a header file with your dll, you can import the dll using the "Import -> Shared Library" function and LabView will create the vi´s for you.
Mike
Message 14 of 26
(1,844 Views)
thank very much for helping me mike and I know I am asking alot but I really don't have any second choice because in my country no body have this talent in labview and its really kind of you 🙂
the question is: how can I know if there is a header file for the dll file that I have??
this is my email if you can talk to me om msn messanger
cool_reem@hotmail.com
Message 15 of 26
(1,842 Views)
Hi reemon,
i´m not sure, but if there is a header file the name is "*.h". If you want to use the dll you need a description of the exported functions. Without the description i see at the moment no way to use the dll. If you can find a description you can create your own header file to use the LabView function.
Mike
Message 16 of 26
(1,833 Views)
thank you mike and I am working with the activeX method,
guys if anyone has the vi to send an sms I will be thankfull, or anyone has worked with this area and have more information about it please help me with it
Message 17 of 26
(1,830 Views)
does any one knows where to find a library for the  Dell TrueMobile 5100 Tri-band GPRS PC Card??
Message 18 of 26
(1,807 Views)
Message 19 of 26
(1,802 Views)
you are my HEROSmiley Wink............but this is not a library that is used in labview!!!!!!!!! it is a pdf file that describe the productRobot Sad
Message Edited by reemon on 04-09-2008 12:15 PM
Message 20 of 26
(1,792 Views)
