how to connect SQL server data base remote PC
hi,
     how to connect SQL server data base remote PC.
(5,075 Views)
You can use NI LabVIEW Database Connectivity Toolkit.
(5,059 Views)
Connect to what?
(5,054 Views)
If you are wanting to connect to a database on another computer you can do so using a variety of methods. What exactly are you trying to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,049 Views)
yes i used Labview database connecitity tool kit.connect local data base its work now i try to connect remote data base(Sql Server).
1).SQL server database
2).sql odbc driver
(5,021 Views)
Basically the only difference is the connection string you use. The one you are using now points to an instance on your local computer. The one you need to.use points to the instance running on the server.
Mike...
LabVIEW Champion
(5,017 Views)
https://www.connectionstrings.com/
LabVIEW Champion
(5,014 Views)
