09-26-2019 05:50 AM
hello master , can you give me advice , im confuse how to create program comparison , below is little piece from the formula that im trying to fix
=IF(x>=3;10;IF(x>=2;20;IF(x>=1;30;IF(x<1;40))))
x = input number ,
any advice or code will help me thanks
09-26-2019 06:12 AM - edited 09-26-2019 06:14 AM
09-26-2019 06:42 AM
Hi kucink,
As GerdW explained, one option is the Case Structure and wiring x to your selector.
Another option that might map more closely to your input statement is the Select node, which you could create a series of.
A discussion of "if" in LabVIEW can be found here: The LabVIEW Equivalent of an If Statement
09-26-2019 08:05 AM
09-30-2019 02:23 AM
finaly i can solve it , thanks for help guys ![]()
09-30-2019 03:28 AM
